CANT GET CAR TO START
#31
PM "mase1"... he has helped people out in the past, and can usually fix things in the tune without having to be with the car (I think he has done that many s2000's, he knows the settings for particular mods).
If he asks you detailed questions, just give detailed answers.
John
John
#32
ok, cant get it to start again! It will start every once in a while and die right away, for the most part it just keeps cranking. Can someone please help I want to be able to start my car everytime!!!!!!
#33
#34
you also have to wait for the the fuel pump to give the fuel to the engine. The AEM doesnt like to just start right up. Also if it is cold out. Then well, good luck. I have an Odyssey PC680 and AEM that is almost impossible to start when it is under 30degrees.
#36
Originally Posted by 03silver2000,Feb 6 2009, 09:01 PM
No, its on a basemap from jeff evans
#37
I have a similar prob.. but happens only sometimes. I don't have enough cranking powah. It's should be at least 500. I need to replace mine with optima red top, which has 800 cold cranking amps. It can start up a tank. What voltage does it sit, when you turn the key over? should read at least 13.5.
#38
The batt. is dropping low now, its a new batt. but because i have tried so many times. I am going to charge it todayy at my work and be back at it tonight.
Jordan
Jordan
