CANT GET CAR TO START
#22
That COULD be the problem, I'm in Cali and the coldest it got here when i was driving was like 48.
Not sure though man, once my car started on the stock ECU i tossed my keys on the floor since I knew the EMS was done. AEM can fix it though, you're not COMPLETELY up S*** creek. How old is it?
#23
Banned
What size injectors? Try giving it a little bit of throttle when it starts on the stock ECU, if it responds and runs it seems your EMS may be the problem.
I had a dead battery on the s and bought a new and had to replace the new one too. Could be a bad new battery. Take it to autozone and get it tested.
#24
He already said he could keep the car running if he gave it gas so I don't think that's it. The alternator keeps the battery charged, but he said his battery was JUST charged fully.
#25
Banned
^ i know that's the same problem I had with the wrangler was it would only run while giving it gas... Same issue.
He said he replaced the battery, could be a bad "new" battery. Happend to me when i replaced my batter on the s.
#26
YESSSS I got it...with alot of help from tech. support at aem! The car would give fuel when the ignition was turned to the on position(priming) but the map was scaled to not give fuel while cranking!
#29
well, he had me change the crank injector table, I did that on the 1052 calibration that comes with aem and it worked and was running on it. Than I did it on the map from evans and it would start but die, so I emailed jeff to see if he could just revise it, cause I dont want to mess with it not being a tuner. I am just happy that my ecu isnt fried and their was no majob problems! Well anyways I bought a new batt. ha, it would be time soon enough anyways being my factory batt. from 2003.
Thanks for all your help guys!
