built engine
built engine
i was wondering about how much i have to build as in upgrade my engine to setup my car for sucess in having an inlinepro kit running at 10psi. do i have to do it all at once or should i do it b4 i get the kit.
thanks
thanks
so lower compression pistons would b outa the pic cuz i would later would like to increase the boost to 12-14psi but by then i would have to sleeve the block am i correct?
Our 3mm headgasket lowers the compression to safely run 14-17psi maybe even more according to the TUNING.
We have made over 400rwhp for many of our customers running our gasket daily driven. with some race gas you can turn the boost up and make around 550rwhp depending on the turbo
