Breaking bolts on manifold/wastegate port
okay, I'm wondering if there is a super strong, super high temperature rating bolt that I can use because this is the 3rd time that this bolt has broken! It is the bolt that mates up the wastegate to the manifold on a revhard manifold.
The first time I was just using regular bolts from home depot and these broke after a couple of months. I then replaced them (both of them broke off and I had to reverse drill them out) with high temp studs from my tuner. Since then, only one has broken and I replaced it with another stud from PartSource and that too has broken about a month and a half into its use.
I have replaced it again with the same one that I had laying around but am wondering why this thing keeps breaking. Is it the heat? Is it the vibrations? When I look at it, it's completely flushed with with maninfold tapped hole and it must be drilled out, but why oh why does this POS keep breaking off! It's not hard to do, but just tedious and I know at some point, it will break and I won't havev my drill to to help me!!
Does someone make a really high heat bolt or is something else the cause of my bolt sheering itself from the manifold?
Rev-hard manifold. LOL I've broken 3 of their manifolds and plenty of hardware. God they're horrible and a bunch of liars as well.
I found a supply store that offered a better grade, that helped. Home Depot hardware WILL FAIL.
Use anti-seize (the grey stuff with powdered aluminum) for install, that helps.
go to a local bolt supplier and ask for the highest grade bolt they have in that size. i'm lucky and have "the metric store" in the next town over, they have much much better hardware than the cheap home depot stuff and its the same price.
If I hit a brick wall and there's nothing there, would anyone be opposed to taking a payment from me and getting one of you kind souls to pick some up and ship it to me?
Originally Posted by skool u,Sep 3 2010, 01:10 PM
Yeah, I'm not too sure if we have any real good stores around my area, but I'll have to do some searching.
+1 on McMaster. Otherwise I'd use a grade 8 or grade 10 bolt. Or you can also use the Stage 8 locking bolts. That would ensure that they also stay on since their locked and won't be loosened by vibration caused by the motor.
