Boosted AP1 w/ AP2 2.2L
I am installing my Greddy kit on a local members API with an AP2 engine (Block Head and Cams). Currently he is revving the motor out to 9K and I am a bit worried that he is going to drop a valve or have issues at running above Hondas rev limiter on the AP2's.
I am going to do a ruff tune to get him by until he goes to the tuner and I want to make sure I don't have any part in a engine failure. As a precaution, I have already checked the valve lash, put in new plugs and did a compressor and leak down test. All tests went well but I am a little concerned.
What is your suggestions should I lower the rev limiter to 8500 or leave it a 9000?
Is there anything other than the springs and cams that should be replaced to allow him to safely hit 9K?
i have run 8.5k for 50k miles on my ap2 motor. On my setup i didnt make anymore power from running it out to 9k anyway.
To be honest, i'd be more concerned about giving him any tune before getting it tuned professionally.
I will take the rev limiter down to 8500.
^ beat me to it.
Between the turbo size and it being an AP2 it will run out of breath before you get to 8500 anyway. Most dyno plots on stock motors will show this.
Originally Posted by urBan_dK,Feb 23 2009, 02:01 PM
With both the AP2 engine and the turbo running out of breath well before 9k on a 2.2 L engine, I think revving to 8.5k would be a no brainer.
Is there any cases of a AP2 motor popping at 9K ?
Originally Posted by dsddcd,Feb 23 2009, 02:29 PM
I agree, though you need to plot and acceleration vs. mph graph first to prove the best shift point, on my AP1 this was app. 8750. He really wanted to keep the 9K redline, so I had to get educated on what the adverse effects of running it at higher RPM.
The only interesting point in this case is that you are introducing FI into the picture. I've actually read that boost makes it easier to run a higher redline since it helps push the piston through its travel rather than the extremely abrupt changes when NA. I probably butchered that explanation but it's something to think about.
And your point about ideal shift points is well-taken, but I really do think that even after that you will see something well below 9k on a small-turboed AP2.
