Boost into the crankcase is bad
Old 01-21-2007, 10:21 AM
  #191
fperra's Avatar
Originally Posted by kane.s2k,Jan 21 2007, 11:08 AM
FPerra has his car set up a bit differently from what is recommended by the manufacturer. He has a breather filter on his KV on the breather side so his cannot create a vac. in the crankcase which is why he was talking about a air pump.
You are correct in how my car is set up, but it does create a vacuum when the engine is running under vacuum conditions. Under boost, the crank is vented to atmosphere. If I run the front KV to the air intake of the turbo, then it is vented there. However you do it, no vacuum is created under boost. Hence, that is why I am thinking of using the air pump to generate a slight vacuum under boosted conditions. I think there are a few more HP to be gained with such a setup. Check out this forum where the LS1 boys are talking such a system.
http://www.ls1tech.com/forums/showthread.p...t6193994&conly=
Old 01-21-2007, 04:20 PM
  #192
snowboardgeek1's Avatar
Kane, yes I am the same guy. I hope you don't think I was putting down your product in any way. I am seriously considering purchasing it, as long as it does what I need it to do. From your explanation, it will achieve the results I'm looking for.
Old 04-04-2008, 07:28 PM
  #193
samus143's Avatar
Hi guys, sorry for the revive. I was trying to do some research on the Krank vents but the links on this thread don't seem to work for me, where can I purchase a set for my s2000? I saw this on ebay:
http://cgi.ebay.com/ebaymotors/Crank-Vents...bayphotohosting
but I am skeptical and would most likely purchase the kit that everyone else is using, Thanks.
-Sam
Old 04-06-2008, 02:40 PM
  #194
JoeyBalls's Avatar
is this why my Oil Dipstick is sometimes "popped" up, Taon at P-Tuning said he had the same issue on his S2000...........
Old 04-06-2008, 06:54 PM
  #195
samus143's Avatar
Yes Joey, boost maybe causing your dipstick to pop off. From all the research of others in the forum, I've read that our pcv valves are not intended for boost so pressure from the manifold is sometimes "boosted" back into the valve cover causing gaskets to leak and dipsticks to pop off as well as other issues. From what I've read the Supra pcv DIY eliminates the problem also at a fraction of the price of Krank vents, I will try that mod first before I purchase a set of Krank vents.
-Sam
Old 04-06-2008, 07:20 PM
  #196
9kFever's Avatar
my dipstick used to pop up due to blow by. Honda rebuilt my motor and it still did it though so who knows. This was when my old car was NA.
Old 04-06-2008, 08:56 PM
  #197
Asura's Avatar
Krank vents in stock. Contact me.
Old 04-19-2008, 07:37 AM
  #198
S2kracka's Avatar
[QUOTE=samus143,Apr 4 2008, 09:28 PM] Hi guys, sorry for the revive.
Old 04-21-2008, 02:31 PM
  #199
RISLAR's Avatar
Try this:
https://www.s2ki.com/forums/index.ph...f=142&t=513733
Old 04-21-2008, 04:37 PM
  #200
TRBOKEV's Avatar
Originally Posted by RISLAR,Apr 21 2008, 02:31 PM
I'm going with this supra PVC valve. Should I get the original one from Toyota or get one of the replacements from Pep Boys?
Quick Reply: Boost into the crankcase is bad
