Boost into the crankcase is bad
Old 08-29-2006, 05:30 PM
  #171
GDM S2K's Avatar
Originally Posted by flexer,Aug 29 2006, 05:26 PM
GDM,
Correct a 1/8th of the price, but like Kane says......You get what you pay for. They are brass not nice and polished. Maybe I will put up a picture of mine so you all can see. That work for you guys?
J. R.
i for one am form over function so thatnk you for posting that info for me. if anything ill have it coated silver woot woot
Old 08-29-2006, 06:08 PM
  #172
revhi's Avatar
:edit: Never mind read through 4 pages, I guess its still not settled if the front one is needed.
Old 08-29-2006, 07:57 PM
  #173
timg's Avatar
7775K62 Brass Spring-Loaded Piston Check Valve 1/4" Nptf Dryseal Male Connections, Viton Seat
That's the one I used. There was something about them that built up pressure, not vacuum in the crank case. The one on the front cover may not have been able to vent enough gas.
Tim
Old 08-29-2006, 09:01 PM
  #174
kane.s2k's Avatar
Those have very small openings from just looking at the description. They might not be able to vent enough.
Old 08-30-2006, 08:23 PM
  #175
timg's Avatar
It seems that the 3/8" McMaster ones are the minimum required. If I have the chance, I'll try them out. In the end it will cost more than a set of KrankVents, but I do have two turbo cars to put them on.
Tim
Old 08-31-2006, 05:03 AM
  #176
GDM S2K's Avatar
Tim
TURBO MONTE FTW!!!
Old 08-31-2006, 05:17 PM
  #177
flexer's Avatar
TIMG,
Correct. Anything under 3/8th I believe would be undersized as that would be a smaller diameter than the stock line. Honda did the leg work and found out what size to use for us, so I would only go 3/8th or bigger. Good luck all.
J. R.
Old 10-03-2006, 01:19 PM
  #178
Banned
JDM S2000's Avatar
is there a free or cheaper way of achieving this?
Old 10-03-2006, 02:32 PM
  #179
flexer's Avatar
Thats the cheapest way I know. If others know a cheaper way please chim in, but thats the best I can do.
J. R.
Old 10-29-2006, 09:50 PM
  #180
VegaS2k's Avatar
I will be going to have local guru Mike Angel from FactorX engineering fame out here in Vegas to diagnose my almost lack of boost on my comptech...Is it possible that the PCV valve can be the culprit? I know for sure it is functional, as I can hear it working when I test it(valve when you shake it and listen), but I do not know if it directly or indirectly causes my almost lack of boost in the car...anyone?
Quick Reply: Boost into the crankcase is bad
