blue emanage with profec-e01
I did a search to see if there is anyone else who has encountered similiar error code: there was another documented case of the same error code. The owner stated the cable to the emanage unit had come loose and after he re-secured everything both units worked fine and the error code went away. I would try checking all connections. Asides from that there have been no other documented cases....hope that helps.
