Blown 3mm head gasket
Old 11-02-2009, 11:04 AM
  #121
dibi's Avatar
getting ready to reinstall the arp studs into the block. I don't have any arp thread sealant to put on the threads,
Should/can i use something else? if so what would you guys suggest?
This is just for threading the bolts into the block, i have the molylube for the bolt instalation.
Old 11-02-2009, 12:42 PM
  #122
passmans2kny's Avatar
i just ordered a 2.5mm hg from cometic, ill let u know how it goes
Old 09-25-2010, 08:26 PM
  #123
1SlowSi's Avatar
Originally Posted by Revenge,May 11 2009, 09:38 AM
So is this a trend, the 3mm HG and 20+psi the HG is a short lived thing, seems like at 18psi there were a lot less issues but going past the 20psi mark they seem to give out a bit more? Or is it with the better flowing manifolds produce more CFM?
Im bringing this back because of this post lol. As soon as I went to the sidewinder manifold and 6262, 21 psi... POP, there goes boost in the cooling system.
Old 09-26-2010, 12:36 AM
  #124
Spoolin's Avatar
Too much timing at boost hit and was probably detonating. Set your timing up like mine and you wont do that anymore.
Old 09-26-2010, 04:18 PM
  #125
yea this was my problem all along, i did the same thing and replaced almost as many pieces of the cooling system as u, when it was the hg all along
Old 09-26-2010, 04:20 PM
  #126
AusS2000's Avatar
Sounds familiar.
Old 05-10-2011, 06:32 PM
  #127
TonysMI4's Avatar
I wanted to bring this back so I can ask how the 3mm's are doing now? Iv read this whole thread and what I got from it is...
. Use the HG spray on all sides before installing
. Tq down to 70 then 80 then 90 in the order the book states, then back off 1/4 turn ( or under 90 ) then back to 90.
. Dont boost over 20lbs. Lets say 18lbs of boost is good.
. Use ARP head studs.
I think thats everything. If Im missing anything please let me know.
................QUESTION................
Im running....
IP stage 1 with hondata flash pro.
6265 turbo
id1000's
Stock HG
pump 93 gas
Walbro Fuel pump
13lbs boost
(Made 360hp)
I would like to know how much more power I would get and how much boost I can run if....
I run IP fuel return system (for my 2007 AP2)
added inline Bosh044
Run E85
Change IP log mani for a Ram Horn Mani.
ALSO..... what if I install the IP 3mm HG.. ???
Old 05-10-2011, 07:05 PM
  #128
o'malley_808's Avatar
Originally Posted by MisMyS
Originally Posted by AusS2000,May 3 2009, 05:19 PM
SCE has three types:
ICS Titan
Pro Copper
Self Sealing Titan
Which should I get?
It was only availible in the ICS (Internal Combustion Seal) when I bought it but if the Titan version is availible that would be nice.
I was wrong it is actually .093" or 2.3622 mm.
Just remember you will have to retorque after it heats up the first time.
Does anyone know how his SCE headgasket held up? Curious to know how mine is going to make out?
Old 05-11-2011, 12:59 AM
  #129
LukeS2K4EVA's Avatar
Hey guys. Newbie turbo owner here. Finished my build 2 weeks ago.
I havent had time to instal my gauges yet. Gonna do them next week.
But for now Ive been using the OEM cluster temp gauge to monitor my temperature.
When I was NA it would always sit just below halfway, like 1 bar below halfway.
However since ive been turbo, ive noticed that on a few occasions the temperature has jumped a bar and sometime two bars to just over halfway! But it only lasts like a couple minutes then it returns to normal temperature.
Is this normal or do I also have an overheating issue.
Should the temperature increase now and then a bit or should it always remain constant no matter what?
BTW stock motor, stock gasket! we not doing big numbers. Less than 300hp @ 6psi.
Old 05-11-2011, 07:02 AM
  #130
spectacle's Avatar
To know if you're overheating, you have to know what those bar temps actually mean. Take a look at this:
Your stock gauge layout is on the left. As you can see, if you're halfway on the stock layout, you're at least @ 235*. That's pretty much the danger zone. Unfortunately, the resolution on the stock cluster is so bad its a crap shoot between the third and fourth bar. I wouldn't want my car going above 210*, but there's no way to know with the stock stuff.
Remember, the stock thermostat and fan come on at 190*...that's the temp the radiator and fan are trying to maintain. If you're @ 235*, there's a limitation somewhere that needs to be addressed.
Quick Reply: Blown 3mm head gasket
