Blowing Dipstick - The latest solution ? And temps
Old 08-08-2024 | 12:04 PM
  #21
jmholloway's Avatar
On an ap1 what would you use to ditch the PCV/replace the connection?
I already have an overflow for coolant already which is good and i have a catch can but just need to change it to two inlets with a breather
Old 08-08-2024 | 12:14 PM
  #22
flanders's Avatar
Use a plastic or metal barbed elbow, just check diameter to get snug fit.
This is from a Swedish dealer but just to show what I mean https://www.do88.se/sv/artiklar/boj-90-grader-13mm.html
Check the construction on your catch can as well, not all are made to accept inlets.
Also most are usually way to small and with useless baffle system.
Here are some examples of well constructed universal ones https://www.nukeperformance.com/cate...oil-catch-cans
The following 3 users liked this post by flanders:
jmholloway (08-09-2024), Kyle (08-09-2024), Spoolin (08-09-2024)
Old 08-09-2024 | 11:49 PM
  #23
jmholloway's Avatar
struggling to find a dual inlet one in the uk apart from the nuke which is to big for my bay. There is one on eBay but only hold 150ml but assume that’s ok as long as I monitor it regularly
Old 08-11-2024 | 08:17 AM
  #24
flanders's Avatar
If it's only 150ml then it probably just going to blow straight through, you could always go for two smaller ones instead.
DanielB
09-17-2021 07:20 PM
EGbeater
10-03-2018 05:36 AM
Spec_Ops2087
21
07-19-2011 03:27 PM
zbrewha863
Jacksonville
12-02-2010 01:53 PM
sIIooo
11-15-2010 09:33 PM
Quick Reply: Blowing Dipstick - The latest solution ? And temps
