blow off valve noise at part throttle
BOV is opened whenever the vacuum pressure is greater than the spring pressure holding it closed. You could probably increase the spring pressure so it's closed at part throttle but it may not open as quickly for shifts. If it's open in boost something is wrong with the BOV or how it's setup. If your unsure have your tuner check it out.
SLiCKYV
02-16-2004 08:09 PM
