base map turbo s2000 australia help
im hear in australia and there is not many aem tuners around so having the car running would be a great help the base map on hear wont get it running and the car will be geting tuned in the next two days so im in need bad of a base map that works so he dosent hit me with an extra 500 to get it started hear is my specs
gt3037r turbo
3mm headgasket
785cc ultmate racing injectors
aem 1052
38 mm turbosmart wategate
turbosmart street fule reg
walbro 255lh fule pump
gt3037r turbo
3mm headgasket
aem 1052
im in canberra the capital and jake edwards is tunning my car he is the only guy that is a good tunner in canberra but this will be the fist aem he has tunned i think he is a specilst with microtech and motech
Don't worry too much. Just follow the instruction with the aem and set up the car before the tune if you are good at fiddling with these things. The aem is very similar to the motec. It shouldn't take too long to figure out. The tune will be similar to a SR engine with vtec cam and 9krpm. I have a base map for a built, decompressed engine with 1000cc injectors. Let me know if you need it.
