ARP Head Bolts and head gasket questions
So I just bought a new short block from Honda and I will be swapping my head over to the new block and I know they say to replace the head bolts so I was thinking of going with ARP. I have seen mixed reviews of how much better they are over OEM. I know the H11/L19 are the best but are they really needed with a Supercharger setup on 20psi?
What are the ARP good for in PSI rating?
Also guys I'm told the ARP lube is a must but I have also heard of other people using other things to lube the studs. Like paste and engine oil/engine assembly lube.
And should I use copper spray? A lot of the threads are a little older and a lot of yes and no's.
I was also wondering if I should do anything else while the head is off? Are springs and retainers needed for a 2008 with 15k miles? From what I read no they aren't.
Sent from my iPhone using Tapatalk
