Apexi turbo timer
Apexi turbo timer
I attempted something I probably should not have but I guess times are tough now right? Lol
I decided to use this as a guide.
https://www.s2ki.com/forums/index.php?showt...0&#entry7239920
Red wire obviously goes to power(white wire)
Black is ground which was pretty simple.
Green Is accessory wire which connects to the 2 black/yellow.
Blue wire I have no idea
Gray wire connects to handbrake I'm not sure about where to connect that either?
White is for o2 sensor wire(search Function worked that out for me)
Some people are saying that the blue wire is (accessories 2) so would that mean to hook the green to 1 of the black/yellow and the blue to the other?
Does the handbrake function work with the light on the handbrake? If so I have to locate the wire that has power while the light on dash is on/off. But that's my interpretation of how it would work..
Any advice/help would be very much appreciated. The search function only showed me so much. Thanks guys
Go to apexi's site, find the wiring diagram for the model you own, and cross reference that to what wires you need on the s2k.
I had to do this when I had my 99 Si, it came w/a harness, but it wasn't for my car, so I had to modify it.
Post up the wiring diagram for the unit and we can help tell you what goes where.
ok guys this is how it goes
Red goes on white wire. (brown plug in main fuse box)
green goes on the 2 blk/yllw (same above)
blue goes on blk/red (same as above)
gray goes on the green handbrake wire.
black goes on any decent earth.
white o2 sensor goes on pin 16 in the blue ecu harness cables.
everything works perfectly, problems solved guys.. thanks so much for everyones help and patience!
