AP1 Comptech SC on 04 AP2
Old 07-31-2011 | 10:12 AM
  #61
steven975's Avatar
Originally Posted by EOE
Little update, I am seeing the following....
Idle: 14.7 AFR
Cruise: 14-16 AFR
Full Throttle:
2k RPM - 6k, 12 AFR
6k - 6200 rpm 11AFR (Spike)
6200 - 8000rpm......... 13.1
I am very happy with it now. Would like to leave it as is. I am running 7psi.
Should I keep adjusting AFR till 12.5 or keep it at 13.1?
This is what mine does...
2K-6K...11s
6K-6200: 13.5
6200-8700: 11.5
8700+: 10.8
I need to adjust it somewhat to get the top end a little higher, as I'm losing power there, but my vacuum tank got chewed up so I'm driving around with a CEL till I get that from Majestic.
I think high 12s is just too lean IMO.
When it gets cooler out or you run it at night, it could go above that.
Old 07-31-2011 | 11:51 AM
  #62
EOE's Avatar
EOE
That 13.1 won't change no matter how low I go. I am about to drop it all the way. It's weird, other rpm range changes but not vtec
Old 07-31-2011 | 12:01 PM
  #63
EOE's Avatar
EOE
Bottomed out and now it's 13.8. Sigh
EDIT: So full bottom it seemed to run weird and sloppy not to mention AFR up top was 13.8. I backed off 1.25 of a turn back up and AFR is back down to 13.1 bit. So weird. Seems to be running strong but I am concerned at this point.
Step colder plugs and boost gauge will he going in next weekend.
Old 07-31-2011 | 12:12 PM
  #64
james0933's Avatar
Change out those plugs. That might help. Do you have an aftercooler?
Old 07-31-2011 | 12:34 PM
  #65
EOE's Avatar
EOE
Yep, aftercooler in. Running fine. Need to borrow friends gauge and watch my IAT for a bit.
Old 07-31-2011 | 02:09 PM
  #66
steven975's Avatar
I monitored my IATs via Torque on my Android phone via bluetooth OBD2 scanner. The reason I got it was to read codes, but it has some monitoring built in, too.
I am in the low 50C range when moving, but it can creep up over 70C (158F) sitting with the motor running.
Old 07-31-2011 | 03:08 PM
  #67
james0933's Avatar
How much psi are you running?
Old 07-31-2011 | 03:51 PM
  #68
steven975's Avatar
6psi pulley. I see 5psi and make 305HP
Old 08-01-2011 | 06:26 AM
  #69
EOE's Avatar
EOE
After some research I came up with the following... Since I cant go below 13.1 AFR in the top end I should check the following...
1) Check Voltage on the Fuel Pump
2) Buy a fuel pressure gauge and check fuel pressure.
Anything ales? My WALBRO pump makes bunch if whine noises and primes really loud. But people say it's normal.
Old 08-01-2011 | 07:07 AM
  #70
james0933's Avatar
^yea normal for the pump to whine, especially when it warms up.
What psi are you running? Verified?
Is this on a ap1 or ap2?
Do you have any exhaust mods? Testpipe maybe?
Quick Reply: AP1 Comptech SC on 04 AP2
