Anyone not running any oil cooler ?
Hey guys, so my new kit is requiring me to delete my oem oil cooler for proper fitment of the manifold. Im not really a fan on the idea but I think it is required. My tuner says its fine to delete as well as pang from Pfab. I will not be running any oil cooler, was wondering if some of you are doing the same with zero issues. I will be looking into an after market oil cooler after the install and tune once I save up the funds for it. What you guys think?
The factory oil cooling is just the coolant lines that run into the block right where the oil filter is. I have seen plenty of people remove those lines without issue when relocating their oil filters. I will be doing the same as well and hopefully installing an oil cooler later on.
I took my oil cooler off also after installing the inlinepro oil relocator. Alex from sheepey has also said it don't even help. Buddy also said the same thing when I asked him if I should get after market one.
