anyone have pics of their filter relocation setup?
not the best pic but here is my setup
i am running the ultimate racing relocator kit. the bottom line (from the block adapter) runs to the outside of the oil filter and then goes from the center of the oil filter to the top of the block. hope this helps.
(my lines are running to an external oil cooler but the line on the far right will be the same as your setup / its the one that goes to the top of the block adapter)
i was working this out last night when i was putting together my oil lines. Off the block, the outside section of the oil filter is the feed and the center section is the return. As long as the lines correspond to that on the oil filter relocator (it should say 'in' and 'out') you will be good.
reading pressure from the original oil sensor port its also T'ed off to the turbo feed. I know it may read lower from there. The big problem is it falling out of VTEC because of loss of oil pressure at 7.5k rpms and up.
