Any of you FI guys try Seafoam?
Didn't know if the effects would be different by not being NA anymore. Just wondering if this stuff really works.
It's the new ATF in the carb Everyone that I know has used it said it has helped their high milage engine have a smoother idle.
Just be slow with it and be sure to do it outside in a well ventilated area.
It removes carbon build up inside the engine. Steam cleaning just like the water mist does. Of course there are other chemicals in there as well so I suppose this might work better. You just take off a vaccum line (the brake booster line works well) and put it onto the can and spray it into the engine. Just have to work on keeping the engine from stalling and having enough oxygen for you to breathe as well. I had the fire department called on me one time
