Any special technique to remove sc pulley?
Former Sponsor
Yeah don't want to twist my wrist off lol. Will the impact wrench cause it to spin fast enough to break loose even with the other end not held in place possibly?
I also was able to look at a pic and get the housing back on correctly I believe.
Looks sweet in black!!
Don't worry about resistance, the impact will pop it loose with the supercharger spinning a little bit. It happens quickly.
Standard thread not backwards.
They make a tool, its got a handle and an adjustable rubber belt strap, they are used for removing oil filters or holding a pulley in place wile you loosen the nut. It works good. Its a must if your blower is still mounted and you cant fit an impact gun between the pulley bolt and your cylinder head.
