Another MP62 SOT Kit
SOT MP62 kit installed by SXM
AEM EMS w/wideband gauge
RC650's w/OEM clip plugs
Walbro pump
Inline Pro fuel rail
Aeromotive fuel pressure gauge
Custom A/C lines
AEM UEGO
Motor pics
A/C lines
Front view under hood
Walbro pump
Custom A/C lines
AEM UEGO
Motor pics
A/C lines
Originally Posted by Slows2k,Apr 5 2009, 04:15 PM
Tell them to clean the AC dye off the intake hose
Originally Posted by DeadZero,Apr 5 2009, 04:11 PM
Dyno?? :-) Amazing Set-up!! your turn for a full Write up review :-D
It's pretty damn fun to be honest with you. The torque and responsiveness is where it needs to be in this car. The sound will make you smile from ear to ear. I have to save up and decide on a clutch setup now. I havent done a dumped full out hammer down run yet and dont intend to until i upgrade my clutch. I cant imagine how nice and fun it will be to be able to use the full potential of the setup. Right now i am just rolling into full throttle pulls through the gears. 1st to 4th pulls like that are wonderfull and come at much faster pace.
I love the reliability factor and virtually maintenence free operation of the MP62. It's a tight fit in there now, but the SOT guys make a pretty nice kit IMO. SXM also took really good care of the install and tuning. They treated it like it was one of their own.
The first night home i had a RX8 that was wanting to play, but it just didnt work out. It's a much more respectable car on the street now. Now i just need to get some seat time and become familiar.
Originally Posted by Slows2k,Apr 5 2009, 04:22 PM
It looks like they have made a few changes from the last beta car I've seen. (neptuner's) The aftercooler radiator is narrower, and the discharge housing on the SC looks different.
The discharge housing is a different unit. Not from SOT. Fits very nicely and has produced better torque.
Originally Posted by roy365,Apr 5 2009, 06:32 PM
are around 310ish on their Dyno Dynamics.
Slowly rolled the RPMs up there to keep the clutch from slipping.
and you actually made ~3more FT-lbs then I did at reline once all environmental correction factors were removed from your pulls and mine.
The equivalent amount of power can be contributed to the AEM performing the fuel/timing instead of the Greddy ult despite you still having the cat on the car.
Your psi also wer ein teh 7-7.25 psi range.
once you uncork that exhaust ( cat less) the PSI will go down whiel flow and power go up
Once you get your TP and your clutch in you will be making more power then I do at all rpms..... that is until I put the 135mm crank on and get my new clutch installed.
