Air to Water vs FMIC Pressure Drop
#22
Originally Posted by Corey Maurer,Oct 18 2010, 07:03 PM
couple guys on the tib forums used to run that.. most ran the water wetter from royal purple i think it was?
#24
Originally Posted by vxn12,Oct 18 2010, 07:45 PM
For those who are running more than 10lb of boost, would it be better to ditch aftercooler and do water/meth injection? Anyone know how much pressure loss on the aftercooler? Has anyone tried this?
And just to add, if you want to make the most power, typically run more % meth = more timing, more complete combustion. If you want to get more cooling ability then run more % water. You can run 100% of either if you want. Your boost level and set up/tune will dictate some of this so it really comes down to a bit of experimentation. The Typical is 50/50 Water/meth. I've played around with all ratios and for my set up 75-100% meth works best.
If you wan to talk to a guy that ran A non After cooled Comptech SC on 10psi with just water/meth as intake cooling ...talk to bluemetals. I don't think he ended up with good results for long. I believe he scored a piston. He is running nitrous on a new motor now, go figure
#25
I ordered a Frozen Boost Type 118 heat exchanger which will be arriving tomorrow with a Bosch pump. The only bad thing I can say about it is it is a burly bar and plate style, and weighs about 14 lbs compared to 6 pounds or so for the SOS upgraded exchanger. I have been logging results and IATs get up to about 140 with my stock Comptech exchanger.
#26
^^^ good to know Brad, is this an average? What’s the outside temp when measuring & driving conditions?
Let us know what your results are with that heat exchanger after the instillation and if you feel it’s a good alternative to the high $$ SOS exchanger.
#27
#28
Originally Posted by Thunder-rush,Oct 19 2010, 10:10 AM
That's the heat exchanger I installed. As big as a intercooler, very efficient.
#29
Cruising temps at 60 degrees are usually around 115-125 or so. This seems unusually high to me as well, I would think this could be quite a bit lower with a better pump and HX.
Moddiction
08-15-2014 06:51 AM
HoBokEnS2k
11-09-2011 07:18 AM
