air pump removal
air pump removal
so i have ems and removed the air pump, the air box behind the front brace, all vacuum lines to the air control valve, removed big pipe from air control valve to air pump. the only things left to remove is air control vlave and get block off plate and the t lined vacuum line to the evap purge <i think thats what its called> it t's to vacuum line off intake mani.
what i am wondering, if i dont remove the t line to the evap purge<i think its called that>, does it purge with the air pump system disabled? i dont think it does, but wanted to make sure. otherwise, gonna have to dig around and find that bastard. the air control valve removal is just to make that part of the motor look cleaner, i know it doesnt do anything when its lines are unhooked.
anthony
anthony
jimtway1
07-01-2010 10:00 AM
Resident Sicko
01-27-2010 06:56 AM
