Aftercooler pump won't prime
A couple weeks back my topmost aftercooler hose punctured (it rubbed against the alternator pulley) and spewed all the water out. I replaced the hose and now am not seeing any fluid move in the aftercooler. I thought maybe I ran the pump dry and damaged it. So I replaced with a new pump - no difference same issue.
I verified there are no air leaks or blockage anywhere. Confirmed the aftercooler and heat exchanger both hold pressure by blowing in one end of the hose and capping the other end.
I also disconnected the pump from the system and ran two hoses directly from the pump to a bucket. Turned on the pump and nothing happened. I then sucked on the outlet hose and the pump started flowing. These centrifugal pumps require the inlet to be fed with fluid, so that explains why I had to suck on the outlet to get it going.
How the heck do I get the system to prime in the car??? I never had this issue, the numerous times I've taken apart my system.
BTW, I have the large heat exchanger and running the large Johnson (SPX) pump. I had planned a track day tomorrow - it aint happening now
You can then pressurize the pump inlet side of the system by pumping the bike pump while squeezing the outlet hose until it's kinked, and the water pump should prime right up (though it may take 2-3 tries if your system is completely empty like mine was).
Note of caution: If the system is still pressurized before removing the hoses/bike needle, the aftercooler will spew coolant EVERYWHERE. I got myself, my engine bay, my neighbor's car, and my girlfriend's car all covered in coolant figuring this out. Be sure to bleed the pressure slowly.
here is a quick tip. take a rubber tip air gun and with it sealed to the aftercooler fill hole give a short blast of air it will force the air out. just did this flows better than before.
I just turned the pump on and loosed one of the hoses on the inlet/output (can't remember which one) and let it get some air and the pump primed right away. I did this right at the pump.
Sent from my iPhone using Tapatalk
