AEM Water meth
AEM Water meth
hello
i dont suppose anyone could give me some pointers to how to wire the the aem meth kit to the ems, as mase is tuning the car on sat with the meth kit via nos setting on the ems
but not sure what port to wire it to on the ems?
also have a switch to wire in, any advice would be welcomed
phil
phil
I'm positive Mase would know which PWM input to use, but you would use the black ground wire on the controller unit to the PWM wire. You also have to remember that there are 2 potentiometers on the AEM injection to adjust flow of the pump (What psi the injection starts, and what psi injection is at max setting). No switch because the ECU toggles it on and off.. unless you wanted to hardwire a switch to manually shut it off.
