AEM Serial Gauge
AEM Serial Gauge
Can the AEM serial gauge display oil temperature (does it come with temp sensor)? Does it display boost, AFR bascially from what the EMS sees (so u need a boost solenoid, aem O2 sensor...etc) already connected?
thanks in advance
thanks in advance
It does not come with any sensors, out of the box it can only read sensors already on the car ie TPS, Coolant temp, Air temp etc.
If your EMS has built in UEGO it will read the O2 feedback too.
You can make it read oil pressure , oil temp, boost ec, but you need to wire those sensors to the D-plug on the EMS, then set them up in the serial gauge software.
