AEM EMS, What does it NOT do
Old 08-23-2005, 05:57 PM
  #21
Stratocaster's Avatar
Originally Posted by RCR S2,Aug 23 2005, 08:40 PM
EMS won't let you pass emissions in the US (at least in IL.) Even if the air is clean, if ODB-II doesn't work, they send you home.
Thanks, I added it to the notes section for ODBII.
Old 08-23-2005, 05:59 PM
  #22
Slows2k's Avatar
I'll add this one to the FI FAQ, Good thread
Old 08-23-2005, 06:08 PM
  #23
AusS2000's Avatar
Slightly off topic, but where does OBDII live? Is it in the ECU? Or is it a separate module that accepts the same raw signals as the ECU and processes them and creates and ODBII stream?
Aus S2000s don't have ODBII. I'm wondering if that is a difference in the ECU, just lacking the connector, or is there another box it is missing?
Old 08-23-2005, 06:41 PM
  #24
In short the ODBII port is bascly a stanard interface, that has a group of standard protocols (MG, Ford each use differant protocols). The EPA mandated the use of ODBII ports on all US cars manufactured after 1996. It was an effort to help emissions inpectors.
Here is a good link with more details.
http://www.interfacebus.com/Design_A...OBDII_Bus.html
Old 08-23-2005, 06:43 PM
  #25
AusS2000's Avatar
I'm aware of what it is, but I'm wondering where it lives.
I guess the question really is: If I was using an Aus ECU and wanted OBDII would I have to add a connector, a connector and some hardware, or a complete new ECU.
Old 08-23-2005, 06:54 PM
  #26
My guess it would require both. A new ECU that supports ODBII and a new wiring harness with ODBII port. If you want, send me your old ECU and I will see if it works. if Honda did not have to do this on 1/2 of the car world wide, it makes since that if it cost $1 to add anything, they would drop it.
Old 08-23-2005, 07:34 PM
  #27
Slows2k's Avatar
If I had a Aus service manual and ETM I could get you a better answer.
Old 08-23-2005, 07:41 PM
  #28
AusS2000's Avatar
Not sure what an ETM is but the workshop manual we get is fairly generic. It shows LHD with some wiring from the ECU to the OBDII plug. BUt you can't tell if there are devices there or just wire. The RHD image just has a picture of the PGM-FI plug location.
Old 08-23-2005, 07:47 PM
  #29
Slows2k's Avatar
ETM = Electrical troubleshootiong manual. Pretty much a book full of wiring diagrams, pinouts, connector ID and location.
A DTC listing may also help... PM me if you have any specifics
Back to the EMS thread.
Old 08-23-2005, 11:03 PM
  #30
Silver S2k4's Avatar
i have seen my CEL come on with the EMS. Scratch that one off the list. the EMS has a error msg display that triggers the CEL to come on.
Quick Reply: AEM EMS, What does it NOT do
