Aem Ems-Umm?!? Dead Temp Gauge as usual
Originally Posted by wait4vtec,Oct 20 2010, 12:05 PM
i have a series two and would like to be able to see my temps, can someone tell me a specific guage i could buy in order too see my engine temps while driving
http://www.aemelectronics.com/gauges-26/se...tream-gauge-33/
Originally Posted by killabee,Oct 20 2010, 11:12 AM
My temp reads full bar right from jump and has always been that way. My aftermarket temp guage always reads good temp even when all the bars are lit up.
update...turns out temps are WELL within spec so I still have no idea why the temp gauge is reading full...my friend who has a modded evo came over with his usb to serial adapter and it worked perfectly so I guess I need to get rid of my $55 belkin for one like his $15 model...damn it
On a side note...we went and did 2 pulls 1 n/a and 1 NITROUS ...0 knock on both...and an interesting note...when the nitrous starts spraying I have a 30 DEGREE DROP in coolant temperatures well at the sensor anyways lol
First, I agree that if you're running a Series 1 you need at least a coolant temp gauge (any aftermarket tune should have a wideband, but that's a different story).
Second, this sounds like an electrical problem. The ECT uses a simple temp sensor - when the coolant is cold, the sensor is full open. As coolant temp rises, the sensor elements draw closer together providing a lower resistance. It would appear that you have a short somewhere - either the sensor is bad and shorted (and you're reading the radiator coolant sensor in your EMS) or somewhere between the EMS and gauge cluster you have a short.
The Series 2 does indeed display in the stock cluster, but you'll need the proper calibration settings for it to display properly. A google search can find those cals for you.
