AEM EMS timing sync
AEM EMS timing sync
How many of you guys with AEM EMS sync the timing on the first instalation or there is no need to do that since it's a "plug and play" unit
Thanks
Thanks
Thanks
Thanks
Originally Posted by Evans Tuning,Dec 25 2009, 08:53 PM
You MUST always check sync with the timing locked at idle, and 6-8,000 rpm range. I have seen some s2000s with slightly offset timing that needed to be fix, as well as some s2000s with timing drift at high rpm. 90% of the cars the timing is spot on though and needs no additional adjustments made.
I got rid of my timing light years ago and had to go out and get another just to do this. Mine was close but I did need adjustment.
You definatly need to adjust the throttle also.
Where do you get the signal for the light gun?
Number 1 coil pack wire I believe.
Originally Posted by roi,Dec 26 2009, 11:34 AM
Did the throttle no problem
