AEM EMS pins
AEM EMS pins
I need to install my MAC boost solenoid and my EMS directions are showing me which ecu pin to connect too but what can i use to attach the wire to the ecu pin? will one of the other honda ecu connector pins work? I was thinking of just pulling a pin out of the car harness' connector that isnt being used and crimping my solenoid wire to that and connecting it to the proper ecu pin...but does the EMS req a special kind of pin?
just a regular middle size and smaller size pin i think..you didnt get pins with the ems?? you can pull some already crimped pins out of anotehr connector that will work and solder ur solenoid wire onto that wire.
All you have to do is call I can hook you up. I will be working on the beast this weekend.
You need the D Connector
https://www.s2ki.com/forums/index.php?showtopic=737492
