AEM EMS options
AEM EMS options
I am getting AEM EMS with UEGO to go with my rebuild (see sig) and have read a lot about all the extras. I would like some simplified info in this thread for:
1. Gauges (I would like an all in one that can display a variety of vitals, but especially boost, AFR, & temps. I have read up on Gauge-Tech and that looks good, but is there any others you recommend?)
2. Sensors (What sensors do I need, ie map sensor, to make the AEM EMS easier to tune and run the gauges?)
3. Anything Else?
PART NUMBERS WOULD BE AWESOME!
3. Anything Else?
If you get the EMS, then you can get AEM's serial gauge. 19 channels of data with lighted programmable alarms on each. It can swap through channels displayed at a programmed rate until one channel goes into alarm. THen the lights go on and that channel stays displayed. Gauge tech is another multichannel gauge option for EMS.
Need a 3.5 bar MAP sensor if your boosting- AEM sells GM version
Need a boost control solenoid for wastegate if you're going turbo - AEM sells GM version
Need a UEGO sensor unless the EMS's built in UEGO controller comes with one - AEM sells Bosch I believe
That's the bacis. AEM has more real nice stuff on their website, like:
Intake air temp sensor helps trim A/F table- AEM sells them
Exhaust gas temp sensors are nice - AEM sells them
Cool, so it looks like I just need the MAP sensor (seen lots of debate between 2 and 3 bar).
I am not going turbo.
The UEGO comes with the sensor.
It may be nice to have the Intake air temp, especally in AZ.
Thanks for the input Derek.
CourageOO7
08-03-2009 05:41 PM
