aem ems
My questions is with the aem ems do you need a resistor box to run these injectors? Does it matter if there peak and hold or saturated? I bought my injectors so long ago I can't remember if there peak and hold or saturated. How can I check to see what they are by using the aem ems? By just checking the resistance?
after typing this I remembered in the AEM software it lists the resistance of the injectors in the primary injector wizard. the Siemens 756cc's are 3 ohm according to the software so yes you'll need the resistor box.
Are you sure they are 750's?
Most of the ones that are sold are the 60 lb/hour (Especially through Inline Pro)but with added fuel pressure (86 psi) can flow as much as an 880. I know the ones I have were touted as flowing 750 but were actually the siemens 60lb an hour which do NOT need the resistor box.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
Im trying to find a definate answer because people keep saying they do need a resistor box some people saying they don't. they are 3 ohm so i don't know if that makes a difference low impedance. I haven't started the car yet.
Aaron B
05-13-2017 07:38 AM
