AEM EMS + 2 Step
AEM EMS + 2 Step
I do not have 2 step/launch control setup on my aem ems. I'm trying to goto the track friday and im wanting to see if I can get this set up. Is there anyone that can help me through this?
Do you have an aftermarket valve train? 2-stepping is going to cause you to drop a valve with the stock valve springs (I think thats the part that fails).
Use it at your own risk.
my tuner told me a story about a s2000 he tuned that bent 7 exhaust valves because the 2 step was so aggressive. I have a two step on my car right now, but its not aggressive at all. I make about 3-4psi out of a 60-1! Not that i can really take advantage of it anyway due to weak parts in my drivetrain!
If you want to set it up. Go to 2 step wizard in the EMS software. The two step is usually setup around 5k rpms and you can change the timing and fuel and ignition. I would however think twice about setting it up if you haven't any experience!
Originally Posted by kutsujula,Jun 10 2008, 11:19 AM
So what technique are you using to launch at the track, im on 255/50/16 Mickey Thompson ET Streets....
BTW, what were your trap speeds with street tires?
