AEM check engine light question
I have AEM Ems and Ap1 - I'm doing some cluster gauge swapping.
Anyone here knows what pinout in AEM EMS is the MIL LIGHT wire (Engine check light).
I don't know if AEM has or no MIL LIGHT pinout.
thanks
thanks
Now that I know AEM does not handle CEL code which is good for me to know.
yea on my AEM V1 the only thing my check engine light is used for is for if the car starts to overheat set to come on at 235 degrees, john at innovative motorworks did it during the tune session
AEM doesn't have OBDII which means the idiot light won't work like it used to.
That said, you can set it up to work however you like. As the AEM doesn't drive the ECT gauge many use it to show an overheat (as above) but you can configure it to light on any condition you like. Just wire it to one of the available spare outputs.
I just got a tune today, I'm also running aem v1 I was told to not worry about the stock temp gauge because of the fail safe system on the ems the check engine light will only come on if your car temp reaches 241 degrees F. Hope this helps
