AC Fan Question
Old 05-08-2012 | 10:54 AM
herecomesboost's Avatar
Default AC Fan Question
I'll be removing my AC shortly; I plan on removing the AC fan (drivers side fan). Under what circumstances does the AC fan turn on? (AC on? Above a certain water temp? Both?) TIA
-Kyle
Old 05-08-2012 | 11:12 AM
camuman's Avatar
Pretty sure only when ac is on.
Old 05-08-2012 | 11:17 AM
Soul Coughing's Avatar
For some reason, both my fans turn on when it reaches 180 degrees, however, I do use an AEM stand alone. I would personally keep the fan, if you know it's going to turn with the other fan, to keep your temps in check when at low speeds.
Old 05-08-2012 | 11:30 AM
I'm also using AEM (albeit the older 1052). Not sure if it's worth the added weight/space disruption. Anyone without AC only using the rad fan (passenger side)? If so, any trouble keeping the car cool? Caveat: my car sees *very* little street time, so overheating is not particularly a concern, currently. I'm just curious if anyone has run this particular configuration. TIA
Old 05-08-2012 | 11:10 PM
05TurboS2k's Avatar
I'm on the 1052 unit as well, today my LS8 driver failed so I have to use the switch now to run the fans, this is fine I suppose in my case.
The fans only matter below 30mph and at those speeds you're under little load of course thus I doubt there'd be a problem with it even with one fan so long as ambient temps weren't insane. I recall a day on the way to vegas at 125 degrees that I was having serious heat-soak issues around town, that said I needed every bit of cooling I had. Other than this experience I haven't even been close to having a problem even on one fan.
I haven't run with one fan though so I can only speculate but I thought the info might be useful. If I was to pick a number that it would be safe to operate in I imagine the cutoff would be around 90-95 degrees or so that operating on one fan would have the ability bring the car back down to proper temps at a stand still. At speeds as I said earlier I'm very confident it'll never matter.
Old 05-09-2012 | 06:50 AM
Thanks for the response, Greg.
Old 05-09-2012 | 08:15 AM
05TurboS2k's Avatar
We could always do a little testing I suppose, just unplug a fan at the plug right by the radiator and see what occurs. Starting to get near hot enough here in cali to make a few conclusions.
Old 05-09-2012 | 08:19 AM
sata3000's Avatar
I use just one spal fan on passenger side. coolant temps never get above 200 with full blown radiator.
Sent from my SPH-D710 using Tapatalk 2
Old 05-09-2012 | 08:26 AM
Awesome. Thank you
Old 05-09-2012 | 08:32 AM
05TurboS2k's Avatar
Good info, ambient temps in your area?
