9krevvin's Build
9krevvin's Build
I started out my FI obsession on a GReddy kit, It was fun for awhile, but i decided it was time to go big. Here are some pictures of my old setup:
My new build is going to be a custom built Inline Racing Tubular Sidewinder Manifold with a Precision 6262 .82 A/R on E-85.
Here is my current parts list:
Injector Dynamics 1000cc Injectors
Precision 6262 .82 A/R JB
Tial 44mm Wastegate
Tial BOV
Aeromotive 340lph Fuel Pump
AEM Fuel Pressure Regulator
AEM 3.5 BAR MAP Sensor
Supertech Valve Springs & Titanium Retainers
Supertech Valve Stem Seals
ILR Tubular Manifold & Downpipe
Innovative 75A Motor & Transmission Mounts
Hasport Differential Mounts
ARP Head Studs
Mishimoto Fans & Shroud
Mishimoto Radiator Hoses
Denso Iridium IK24 Spark Plugs
PuddyMod Air Pump Delete Plate
P2R Throttle Body Spacer
Hondata Intake Manifold Gasket
Updated Oil Jet Bolts From Honda
Mugen Thermostat
ETC....
Fuel Pump Install
New Turbo and BOV
Tial 44mm Wastegate
My engine all torn down
New Parts!!
New intercooler piping
Powder coated parts
New Mishimoto fans and shroud
Supertech Dual Valve Springs Retainers and Seals
Installed!!
This is pretty much where I am right now with my build. I just got the Intake manifold off and valve springs installed today. I think I am going to send my intake manifold off to be powder coated. (Black???) I will keep this thread updated when I get more done. My Manifold is still being built by Inline Racing.
Tial 44mm Wastegate
Tial BOV
ARP Head Studs
Mugen Thermostat
ETC....
Fuel Pump Install
New Turbo and BOV
Tial 44mm Wastegate
New Parts!!
Powder coated parts
Installed!!
Looks like it's going to be a nice build.
You did upgrade the valves to Supertech inconel exhaust and nitrate coated intake valves; right? If you kept the stock valves and are going for fairly big power, the stock exhaust valves with the added heat can't handle it over time and will eventually warp, wear the guides and will break and drop.
I just just made a thread asking about the gasket, and all but one person (out of about 15) 100% Recommended it.
About the new valves, No, I did not upgrade them. I will be looking at making 450-500WHP right now. Do you think I will need new valves at this power range? I know I could probably make more, and I will some day, But I want to keep it there till I have the money to upgrade the Transmission & Differential. I have already upgraded to AP2 Transmission Differential, & Driveshaft.
The stock valves will warp at 400 whp. That's significantly more power and considered fairly big power. I had my head built after about 3 years (roughly 9000 miles) and 400 whp before going any further with power. The shop that built my head said it was a good thing I decided to build the head when I did and put new valves in because the stock guides were already worn and I had 3 warped exhaust valves that would have eventually dropped and trashed my motor. I'm just giving you a heads up. I'm not some newb here, I have been a member here since early 03 and have had my S boosted for 8 years. I know a thing or two about this car.
I do not doubt you at all, I just wanted to know. Thanks for the advise, I will definitely keep that in mind.
On another note. I want opinions on my intake manifold. I am getting it powder coated and was wondering what color? I have pretty much decided on black, but I am not set on it. Mostly just wondering which black, Gloss, Satin, Matte, Crinkle???
Let me know what you guys think!
Also I should be getting my Turbo manifold from Inline Racing any day now. I will post pictures when i get it.
I myself like the crinkle satin black. I did my valve cover like that and it looks awesome like that and makes the engine bay look so clean.
