90mm bore and boost
Old 10-02-2009, 04:54 PM
PhantomAP1's Avatar
I don't think anyone is running 90mm with F/I... Only the hardcore N/A people run 90mm bore sizes.. And there are only a handful of those guys too.
I wouldn't think a gasket that thin could hold out past 15psi....even with lower compression pistons.
Would the slightly improved displacement really yield higher performance than the ability to up the boost safely/reliably, even if you bored to 88mm?
Old 10-03-2009, 11:21 AM
kutsujula's Avatar
88MM and Oring here.
Old 10-03-2009, 03:25 PM
honda9krpm's Avatar
Originally Posted by ERL_S2000,Aug 27 2009, 01:45 PM
1. Past 89mm you can not o-ring the head and you will run into major issues with gaskets because of the big bore size. Sealing area becomes very small. This is not a big problem with N/A engines but being FI we have very little room to work. I am using a OEM gasket @ 89.5mm. The thickness is .030". Given your deck height after your new setup is install and how much comes off the head if you have it reworked ect ect ect may require you to modify the piston spec before installation do to having a limited amount of gaskets to use. I personally did not want to use cometic in any way esp @ that bore size. I see nothing wrong with a 88mm bore.
listen to ERL
Dont go past 89.5mm
Stick with 89mm or less if you want less headache.
My builder was able to O-ring the block at 89.5mm and I am using a copper SCE headgasket.
Whether this will hold with good boost...time will tell.
FINGERS crossed!
S2K_2003
02-22-2010 07:18 PM
july7543
01-03-2010 12:46 PM
s2kjb
04-02-2007 04:10 PM
d.h
03-30-2007 05:24 AM
Honda-S2000VTec
08-20-2003 10:08 AM
Quick Reply: 90mm bore and boost
