66mm wastegate
66mm wastegate
i have a ramhorn manifold with a 6262 ball bearing, i had a 44mm tial wastegate, i was creeping a lot, my tuning make the cut off a 7500 rpm cause y was creeping, and i alway boost cut at like 7200, last night i put a 66mm precision wastgate, i run the same boost, before 6500 the wastegate is open an run great at 6800 7000 the car bogging a lot, like misfire, is it possible the last programmation cause that? i boost the same boost , th boost stay at 10psi
scuse me for my bad english, programmation= tune, i tune it on the dyno, change my wastegate, the boost is stable and very similar than with the 44mm gate, but at 6800 6600 the car bog a lot, can be cause by tuning? coil pack ? have you trouble with your coil pack?
Is it misfiring? Any more info besides "bog"?
Sent using free Tapatalk - Android FTW
yes look like miss fire, my air fuel is like 10.5 at wot, i will try my crx k20a coil pack, my friend said if my car run good a 4000 5000 rpm it isnt the coil pack, i said the coil pack run good or dont run at all like running on 3 cylinder is it true?
no it can run fine at 4-5k and then not be good at high RPMs
yes, swap to low mileage k20 coilpacks or low mileage 00-05 s2000 coilpacks, and see if the problem persists. If it does, then it's most likely NOT the coilpacks.
Bad WG location? The 44mm is great up to 1000bhp and 66mm just huge. We had control problems with the HKS 60mm because of the size and this one is even bigger.
Other than that it sounds like misfire, checked the plugs?
Try leaning it out, 10.5 is pretty rich.
