600hp+ clutch
600hp+ clutch
anyone running between 600 - 700hp .... i'm curious as to what clutch yall are running. i'm currently running an act heavy duty clutch and pressure plate. it's said to be good for 383 ft-lbs of torque. should i upgrade again or just leave this one till it goes out, and if the answer is upgrade then what do u recomend? thanks
use the clutch you have now unless your gonna get it tuned a slipping clutch and tuning dont mix when you do end up changin your clutch go with Competition Clutch ironman series for the f20's all i sell is Competition Clutch and run it in my car(550hp) holds up grade and have not had any of my customers say anything but good stuff about CC
Originally Posted by GDM S2K,Jan 19 2007, 06:25 AM
you mean how much TQ could it take
In my S2000 I was using an ACT 6 Puck Clutch, ACT Heavy Duty Pressure Plate, and Comptech Flywheel. However, I only put 1,000 miles on the setup prior to selling the car. - in case you do not recall, that was at 597.7whp / 381.4wtq.
Honestly at that power rating I was not expecting the clutch to last too long. Personally I would recommend either a Competition Ironman or Exedy Twin Disc Clutch.
