400whp s2k quarter mile compared to other cars!
Hey guys got a couple muscle car friends, im pretty much the only tuner in the group, but quick question, what is ruining our quarter mile times. 370whp camaro ss run from 12 flat to 11.8 quarter mile on a good launch. Those times will be hard to achieve in a 370whp s2k, but why, s2ks are lighter. is it cause we cant launch at full potential or what is it ? how about both cars with the same horespower at rolling races , what will be the outcome then. Local track is hosting their first roll racing night. what you guys think?
If you guys want a car to race in a straight line and "hook up" set you car up to do so. Put a big strong diff, beefier axles, wide high profile tyres,soft front suspension set up, soft or no sway bar, etc etc and you will go fast but the car isn't designed to do so.
It's made for corners and it's bloody strong at what it was designed to do. It's a fun convertible with everything going for it with the standard to slightly modified motor. Boost it with low profile tires and hard suspension and big hp, what do you think it's gunna do. It's going to bog down or spin or break something...
Every car is a compromise in one way or another unless you have some serious cash....
http://www.youtube.com/watch?v=0zTsEauqW10
Still wishing I would have had DRs...
I managed a 12.8 et with 350ish whp but I launched at 6k preloaded with the ebrake shifted well and it was around 60 degrees at 600 feet above sea level I am supercharged mind you and my boost at 8500 rpm is 9.7 looking at the data log so I am very happy with that. my diff is built though caps and a pinion collar built by puddymod first try I bogged and got a 13.5 not much better than stock second wheel hop and let out 13.8 third time was the charm 20 psi in rear tires rear struts near full hard on the edfc controller and the front full soft and I don't think I am going to do it again I just wanted to see if the car was capable of 12's
