3.5 bar map sensor
3.5 bar map sensor
Is it possible to run the AEM 3.5 bar map sensor with the greddy emanage or is the AEM EMS required to calibrate the map sensor? From searches it appears to be doable but its unclear.
no its not possible, atleast its not easy to do it. I ran into this problem, i hooked up the 3bar and the car would shut right off. with emange you have to use the greddy pressure sensor.
oh great, it just keeps getting more and more simple does this pressure sensor directly replace the stock map sensor? And do i have to calibrate it to the emanage?
Originally Posted by Stratocaster,Dec 31 2005, 04:43 PM
If you want, I will swap you a Greedy sensor for the AEM/GM sensor.
i have a brand new in the box with receipt gm 3bar if you need one
