$275 "3 Test Pipe with CEL Fix worth it?
Originally Posted by afwfjustin,Feb 11 2008, 06:12 PM
The CEL fix makes the car think that it's stock and it will not throw a CEL fix. You can actually pass an emissions test with a test pipe as long as it has this extended bung fix.
The .5 difference is probably very worth it. I'd estimate that it'd make a 5 rwhp difference alone. You're getting rid of another bottleneck so if you can get one done for a good price I would do it.
Originally Posted by skibum,Feb 11 2008, 08:22 PM
A lot of shops won't make them because they can get in deep sh!t getting caught bypassing the cat.
but anyways, yea, i'd say a 3" tp should cost no more then $150 at a exhaust shop. Just two flanges, and a bung. And there is no problem running a 2 1/2" dp to a 3" TP.
I dont know if youve checked this site or not, but here is a link to kteller's web site. He's got 3" TP's for 65, plus a little more for the o2 bung.
http://www.kteller.biz/prodtype.asp?PT_ID=...PageHistory=cat
hope this helps!!
hope this helps!!
hope this helps!!
hope this helps!!
I saw Berk's post. For $275 it's not worth it. For less than $200, it probably is. I'm always surprised by the cost of good welding and flanges. Any shop could make one from press bent 3" aluminized pipe for $50. Trying to find a shop that can tig one from stainless steel with the proper flanges is considerably more difficult. And even then, a one-off made on the car generally won't fit as well as something made in a tight jig based on the stock cat.
Tim
