250CFM Electric Supercharger
Oh boy....look what I found!! Only $560.15!
If you need a boost and can't afford a real turbo or supercharger conversion, this product is for you. The Electric Supercharger is an adapter to either your short ram or cold air intake. It will work on absolutely any air intake brand including AEM, Injen, MimoUSA, Weapon R, Fujita etc. Simply remove your current air filter and put the Supercharger as a replacement, it's that simple.
The supercharger is operated on a 12-volt source. This means you can connect it to your battery to get the power. It uses 2.2 amps from your alternator when turned on and doesn't affect your car performance or battery drain. The Supercharger is connected to a switch inside the car. Whenever you need more power you simply flip the switch and fly away. It produces 250CFM of forced air into your manifold and it very quiet under the hood when turned on. In fact it has a nice aggressive sound, making it seem like you got something bigger then what you actually have under the hood.
A stock turbo from an Audi 1.8T produces 400CFM. Adding the electric supercharger will produce more then half of the power than a stock Audi 1.8T turbo would. There is need to do any modifications to your engine at all. 250CFM of forced air can also be compared to a 15-25 shot of Nitrous.
The supercharger is made out of the finest parts and a certified K&N Filter with Lifetime warranty. Installation is very simple, it should not take more then 15 minutes to Install.
* Produces 15 - 25 horsepower increase.
* Generates 250CFM of forced air.
* Universal Bolt-on, installs on any short ram or cold air intake.
* K&N Filter included.
* Installation instructions and all necessary installation hardware included.
* Pipes are not included, the car must be equipped either a short ram or cold air intake. (If you do not have an intake we would recommend the Weapon R Secret Weapon)
* Universal application. (Unit will replace your aftermarket air intake filter, please check to see if there is enough room by your air intake filter to install this unit.)
nooooooooooooooooooooooooooooooooooonooooooooooooo oooooooooooooooooooooonooooooooooooooooooooooooooo oooooooonooooooooooooooooooooooooooooooooooonooooo oooooooooooooooooooooooooooooonooooooooooooooooooo oooooooooooooooonooooooooooooooooooooooooooooooooo oonooooooooooooooooooooooooooooooooooonooooooooooo oooooooooooooooooooooooonooooooooooooooooooooooooo oooooooooonooooooooooooooooooooooooooooooooooonooo oooooooooooooooooooooooooooooooonooooooooooooooooo oooooooooooooooooonooooooooooooooooooooooooooooooo oooonooooooooooooooooooooooooooooooooooonooooooooo oooooooooooooooooooooooooonooooooooooooooooooooooo oooooooooooonooooooooooooooooooooooooooooooooooono oooooooooooooooooooooooooooooooooonooooooooooooooo oooooooooooooooooooonooooooooooooooooooooooooooooo oooooonooooooooooooooooooooooooooooooooooonooooooo oooooooooooooooooooooooooooonooooooooooooooooooooo oooooooooooooonooooooooooooooooooooooooooooooooooo
Originally Posted by jzz30,May 12 2010, 09:14 PM
just put 4 together and you can make 100hp more!!
Force Flow X4 Brushless Electronic Supercharger
Twin side by side Electric Intake Supercharger System. For those who want more serious power! Designed in Australia, made in Australia!
Kit comes complete with:
•2 x X4 4 inch intake supercharger
•Electronic control unit
•Wiring harness/relay/fuse
•Cabin override switch/throttle activation microswitch
•2 x 4 inch (101mm) - 3 inch (76mm) silicon intake adapter
•2 x 4 inch (101mm) Force Flow high performance pod filter
(or 2 x 2nd adapter depending on installation)
•Full installation instructions and technical support
•Warranty
Please note the 8.0 twin system requires a y-join pipe to connect the 2 electric intake superchargers to your intake system. The y-join pipe is not included in this kit as it should be custom fabricated to suit the space in your vehicle. Force Flow can provide you with information about y-join designs upon purchase if required or you can add a standard y-join pipe to your purchase below.
