2 Questions on Injector
Do you know if 650cc will work to 10-12 psi boost (KW rotrex supercharged)
Second: is the RC injector 750cc plug and play to the wiring & fuel rail of the s2000?
Thanks
Thanks
Injectors aren't measured with how much boost you'll use.
Better judge would be horsepower but I expect that yes they'll be capable of supplying the fuel needs to make the horsepower created with a rotrex at 10-12psi.
I'd go ID injectors without a doubt.
ok...so do you think the 650cc injector can handle 350-370hp?
that's all hp i'm targeting.
markforrester99
05-07-2016 12:52 AM
