1200cc injectors recommendations
![](https://www.s2ki.com/forums/images/s2ki/ranks/com_organizer.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Hello,
After my last tune it seems that my id's 1000 injectors maxed out close to 1.6 bar. What are my options for 1200cc injectors if I want to increase boost? Your recommendations please on a good set as I was very happy with my Id's and it doesn't seem to be available as 1200cc.
Thanks in advance
Chris
Thanks in advance
Chris
I think deatschwerks is the only injectors around 1200cc (1300cc). I've read they are hard to tune on this forum and a couple others but supposedly that was only the original run of them. I did see that Full Race offers deatschwerks with the turbo kits. Maybe give them a call and see if they have luck tuning them.
Thank you guys for your replies. It seems that id2000 is the way to go. And I was almost sure id had 1200cc option until I did my search
![frown.gif](https://www.s2ki.com/forums/images/smilies/frown.gif)
how much power are you making? what fuel pump? if you are maxing out 1000's on race/pump gas you should be making alot of power
FIC Bluemaxx are nice injectors they make a 1250cc and 1450cc, i used the 1450 before and they worked great
On my previous tune with a walbro 255 and a kenne bell boost a pump I made 565whp on a dynapack dyno. I have the pfab ELMT turbo kit with a GT3582R. I had a problem with my aeromotive fuel pressure regulator which I changed to an aem one and found the chance to swap the walbro with an aeromotive 340pump and removed the kenne bell boost a pump. My tuner only tuned the car on the street. Haven't been to the dyno yet so I don't know the power I am making now but most possible will be around the same. Everything is on pump gas on 100 octane fuel.
Originally Posted by bj@jjautowerks' timestamp='1362484610' post='22381117
YOu must be running e85? look into the FIC injectors. They make them in 1100cc i wanna say. Why not just get 2000cc's?
From what I have seen here on the F/I forum around that whp (560) the id1000 max out. Please let me know if you have a different information to check if there is something wrong in my tuning. Like I said haven't been to the dyno yet but at 1.6 bar on street tuning seems to max out on my set up. They are about 90+% duty cycle
