1200cc Injectors
Old 01-28-2009 | 04:40 AM
roi's Avatar
roi
Default 1200cc Injectors
Is anyone using a set of 1200cc?
If so how is your idle?
Old 01-28-2009 | 06:35 AM
jwa4378's Avatar
I believe phils2k is using 1200cc injectors... Could be wrong, though.
*correction... phils2k has 1000cc injectors*
John
Old 01-28-2009 | 06:43 AM
kutsujula's Avatar
What are you trying to do to use that big of a an injector?
Old 01-28-2009 | 06:46 AM
jwa4378's Avatar
*correction... phils2k is running 1000cc injectors*
John
Old 01-28-2009 | 08:12 AM
ScorpionT's Avatar
I take it you are running E85? If youre going 1000cc+ you should be using a standalone, I dont have experience with Hondata but I doubt you can scale those injectors properly.
Old 01-28-2009 | 08:24 AM
kutsujula's Avatar
That's the only reason I can think for that big of a injector is E85, going by ur sig for ur power goal if ur gonna obtain that number on a regular c16 gas then a 1000cc injector and supporting fuel setup would be sufficient.
Old 01-28-2009 | 08:43 AM
tony1's Avatar
Our Bosch 1000cc injectors can safely be run up to 100psi base fuel pressure for anything from 1000cc/min to 1535cc/min of fuel flow. Hands down the best injector you can get for your application.
Old 01-28-2009 | 08:52 AM
Peter@ISP's Avatar
Former Sponsor
i concur with tony1. i'll be giving you a call about your injectors. i cant stand my 1600cc injectors.
Old 01-28-2009 | 09:59 AM
tunedbycft's Avatar
I do use 1200cc injectors and my idle is perfect!
Fernando
Old 01-28-2009 | 01:52 PM
roi's Avatar
roi
Fernando
At what RPM do you idle?
I plan of running normal fuel (no E85 and no C16)
My plan is to boost 29 psi and get as much power as possible
