[W] -10AN welded valve cover, 06-09 S2K
Hi guys,
Been thinking of doing the whole '-10AN valve cover' idea like many members here go for.
They have the AN fittings welded into the front/side of the valve cover and then run sweet stainless braided lines from there to the catch can.
This is my current setup, Rotrex C38-81:
Does anyone know of someone selling a valve cover already pre-welded/ ready-to-go for 06-09 S2K?
Would love to eliminate the ugly rubber hoses and fittings I currently have on and run stainless braided instead.
Also, I notice some guys weld AN fittings into the front, other into the side (similar to breather & PCV location)
Any difference?
Front:
Side:
Any difference?
Front:
Side:
Mine are welded using the stock locations. This way you remove the PCV and run an open breather can for both vents. If you tap fittings for the front of the valve cover, you still need to sort out the crank case vent.
