What tune to use
What tune to use
I just purchased Injen Intake and 70mm tp. Now what cal should i use for this setup? Stock headers and stock exhaust on 06 AP2.
Injen tune or Toda tune? Or maybe using Injen tune with lower Vtec set point like Toda?
I have the K&N FIPK, and a testpipe on OEM header and OEM exhaust. I tried the other tunes, but they didnt give me good results. On WOT pulls I was 13.6 AFR or higher, sometimes 13.9, which I didnt like. On the Toda tune I am in the 12's now, but it still isnt great. It jumps from low 12 to mid 12, to high 12, back down, during a gear, from what I saw. Toda is definitely the safest tune though, for anyone with a test pipe.
With a TP, you should be able to lower your VTEC to 3,700 RPM even with the stock header regardless of the calibration. Try out each calibration and see which one puts you at the better AFR. I'm willing to bet it's the Toda calibration.
The Toda map runs pig-rich, even with intake, test pipe and big exhaust. You guys have to remember, that the canned maps are uber conservative. Hondata does not want people popping motors with any of their maps, and then getting blamed for it. Would be pretty bad for business.
Hopefully in a week I have a nice single and can use my real map again
Well I installed tp today with toda tune, Im still waiting on intake to be delivered..... So I took her for a test drive with new cal and she feels to be more alive with removal of cat. I also was surprised how heavy the factory cat was compared to tp, I was just not expecting it to be that heavy..... I also did a data log at WOT, all seems to be fine for now. I will wait for intake to do another datalog... Thanks for your feed back....
Just wanted to give a update,
Installed Injen cold air intake and I got to say I'm very impressed with quality and overall performance. At WOT vtec sounds crazy...
Thank you all for your feed back....
NeoJFK
05-08-2013 08:30 AM
'ringmeister
12-13-2011 11:30 PM
LagunaAzul
05-06-2011 05:33 AM
