Valve Cover Question
Can the 04-05 AP2 valve cover be used if you have Hondata KPro on an AP1? I know the difference between the AP2 valve covers but I had mine powder coated and had bungs welded to it but now I need to go back to stock. I have only been able to find 04-05 valve covers. If I have the second camshaft position sensor hooked up will it cause any problems?
If you are still using the KPro, the exhaust cam sensor needs the 06+ VC to clear. If you remove the exhaust cam sensor and go back to stock AP1 cam sensor and stock ECU, any VC MY'05 and less will work.
idragmazda
05-01-2010 06:47 AM
