Removing ECU
You need to put your donor KEY next to the key that starts the car. There is a little chip in the key that transmits to a receiver that surrounds the key hole. Think of it as a circular antenna that receives the signal from your key.
Good luck. I will probably be doing this same thing as I am probably going to swap my '00 ECU for a '02 ECU. I have the keys to that ECU.
