Removing ECU
Removing ECU
Hey guys i recently purchased an a02 ecu for MY00 and i need to get it reprogrammed at the dealer, only thing is to lower my costs i need to replace it myself once there. can anyone let me know how to do this?
thanks gents
thanks gents
Remove kick panel by your clutch pedal (with the fuse diagram on it) use screwdriver to unbolt ecu from bracket, unplug ecu, plug in ecu, work backwards till you're back together. that's if they're reprogramming the ecu to work with your car, but I'm pretty sure it's the other way around, and they reprogram the immobilizer to work with the new ecu, which is why some people sell the immobilizer with the ecu.
Originally Posted by JUSTINTHECOASTIE' timestamp='1334175293' post='21598504
Do have the keys to go with the new purchased ecu?
Originally Posted by 3en' timestamp='1334179724' post='21598750
[quote name='JUSTINTHECOASTIE' timestamp='1334175293' post='21598504']
[/quote]
Or by utilizing craigslist/locksmith.
Sent using free Tapatalk - Android FTW
Reviving this thread, I tried installing a pcxa02 ecu on my my00, I have the keys from the donor ecu, so I taped it to the ecu, but it wouldn't start. Just makes the cranking sound. Anyone encountered this problem and is there a way around it? Dealership doesn't want to program my keys for me. soor
